I am wanting to remove any sort of amber plastic/covers, and instead have an amber LED in place of the halogen bulb (all other bulbs will be LED swapped as well, just white). However, I'm not exactly sure how the bulbs and covers work for the front.
The top rack, from center out, is hi - low - turn signal. But what is the bottom rack? I do not know when the inside light is on, nor the outside amber light (parking light I assume?), and the center light is DRL. At that, do each of these 6 sections have their own bulb, or is the color merely discerned via the cover?
Basically, I'm just looking for advice on what steps to take/where to start to get only clear light covers in the front.
Also, if relevant, I have a plug n play HID kit installed in the highs and lows.
Thanks for the input as always!
EDIT: Z-56 Hoe's truck is what I'm talking about for the lights, except for a GMC, and I do not know what it is called.
