climate cotrol question.
a4edwin
ny
i keep my climate control on 78. now it sounds like my a/c compressor cycles on and off is this normal or is somthing wrong. now if it's something wrong what might it be?
WildBill
Do you have the automatic HVAC? when you have it at 78*, what is the temp outside?
chauncey0337
MLT, WA
I believe it's normal for the compressor to cycle on and off. I think mine does it all the time when my heat is on.
A
a4edwin
ny
low mid 30's to 50's weather's been crazy in ny. just seem like it'll swallow more gas with the a/c comp running
ScottL4619
Columbus, OH
If you put it on auto and the temperature is above 40 or so degrees, it will use the AC compressor to dry the air. You will notice the little snowflake on the top of the display when it is being used. I just press auto, and then quickly press the AC button to turn off the AC because I don't really want it running unless I need to cool the truck. If you turn off the AC fast enough, it won't even have time to kick on.
ATL
turn the compressor off, it doesnt have to run
A
a4edwin
ny
gonna give it a shot
Tssonebay
