Clunk noise
josueh95
okay guys soo not every time but often when i go into reverse, not when i put it in gear but when im about 10 feet already moving i hear a clunk noise coming from the front of the vehicle sometimes it feels like its the drivers side other times it feels like the passenger side, also when im driving and coming to a stop it feels as if a small clunk noise is made, could it be an engine mount?
all 4 balljoints are new, outer and inner tie rods are new, pitman arm and idler arm are new, what i do need is a wheel hub on my passenger side but i dont think thats the problem right?
has anyone else had this problem? could it be a loose bolt from a control arm maybe? any help would be aprecciated thanks
josueh95
josueh95
figured out the problem upper control arm bolts where becoming really lose causing the clunk noise all works perfectly now
Yukonboy2014
Always make sure you come to a complete stop before you shift gears. Saves your transmission from alot of wear, and will ultimately reduce its service life drastically.
blanchard7684
