Cluster Reprogramming for Radio Button upgrade
2015TahoePPV
This is a pretty deep and overly complicated question, but I'm hoping someone here has real world experience that they can share.
My 2015 PPV came with no radio controls on the steering wheel. In my research, I've found that all 2018- newer Tahoes came with the wide/ color cluster standard (with radio controls).
My goal is to keep the PPV cluster/ 150MPH speedometer AND have functional radio buttons/ Driver Info Center controls on the steering wheel. I have an aftermarket Alpine Flatscreen radio, with the interface module from Crutchfield.
I have added the wiring pigtail from Phil, a leather factory wheel with the buttons, new clockspring, etc.
I have sourced a 2018 PPV cluster from a salvage yard.
I need to get the cluster programmed to my VIN to avoid any security issues/ display the correct mileage, etc.
The last time I asked WAMS it was too much work, they didn't want to do it, they told me to buy a Denali cluster. I don't want a Denali Cluster, I want the PPV cluster.
Can the dealer reprogram a used cluster with my VIN? Everything I've read said this should work. Does anyone else have any vendor experiences that they've seen work? I'd appreciate any help!
I don't know why you couldn't just have the cluster programmed to your vin by any cluster repair shop, but if there is something inherently different firmware wise that might be why wams declined as it is not something commonly done enough to warrant the extra work.
I had not really looked at the ppv clusters for 2015 it looks like one you would have found in a caprice, weird.......
I would assume as long you have upgraded the hmi/radio, clockspring and steering wheel then the cluster should a breeze
***edit I see you note alpine and module, does the module allow for complete radio control thru the "most bus"?
2015TahoePPV
2015TahoePPV
It does, you can program each of the buttons to do custom outputs: https://www.crutchfield.com/p_794ADSMRR/iDatalink-Maestro-RR-Interface-Module.html
Apparently the Denali cluster (and the 18-up) clusters have the extra circuitry to make the radio controls work, you have to run a circuit from the cluster through the radio plug back to the BCM circuit for it to work with an OEM radio, but the Maestro is plugged into the radio with a splice at the BCM connector in the ALDL port.
2015TahoePPV
2015TahoePPV
Is there a cluster repair shop you've used that I can send this 2018 cluster to for a vin reprogram? I'm assuming that by reprogramming the vin, it allows the mileage to be read from the BCM?
I've seen guys on Youtube plug in the updated clusters and the button functionality works (mileage doesn't display), but that will cause you to risk the security function to lock you out/ brick your truck, which I'm not interested in, lol.
I am familiar with the maestro I have one in 2012 and a ppv cluster in 2012 which I bought new and it came programmed to my vin from the seller.
all plug-n-play on the gmt900. I have messed with the radio a bit on my 18 but not the cluster. I understand how it works and the need to add the circuit for the new cluster/steering wheel (most bus). when you did the programming for the maestro did it ask you for details like which steering wheel controls you had? just wondering as that could be another potential roadblock Idatalink is able to modify programming but not sure how that would all pan out.
2015TahoePPV
2015TahoePPV
There's a menu in the idatalink screen that will tell you if the buttons are working, the radio isn't seeing any of them. I'm certain its because of the MOST BUS being absent. I'm not sure why WAMS didn't want to do it, all of the PPVS should be equipped basically the same, so its not like they'd have to reprogram the magride or anything. I just want the VIN changed in it, maybe reset the hours (since I have a new engine) and be done with it.
well sorry I can't be of more help, I would check around locally and see if a speedo shop can program the vin,
when you get that sorted you will likely want to do a reset on the RR so it will see the bus, at 1st power on it detects everything so i am sure a reset will be needed.
you could maybe try reaching out to obd genie and see if any of there products will do it.
BLACKTahoe2016
