Code P0700 and P182E - Need help
kevshoe
Hi all. Background. 2011 Suburban (I know...it's not a Tahoe but I have two of those as well :) ). This is the wife's daily driver. About a month ago, she had these two error codes show. It also showed stabilitrak and traction control were disabled along with putting the car in limp mode. She was close to home so got it back no issues. I cleared the codes and took it for a drive. No issues. Did a quick search on the internet to see if I could diagnose the issue, but didn't find anything.
Tonight, as she was coming home, it happened again but this time did not go into limp mode (traction control and stabilitrak were both disabled again). I pulled the codes and then drove around the neighborhood and it drove fine. I then came back home and cleared the codes and took it for another spin and it did not set the codes.
Not sure where to start looking with this one so any help would be appreciated.
Thank you much in advance.
HiHoeSilver
Away!
Chicago
Trans codes. Start simple and check the wiring at the harness. I think there's a sensor you could try, too.
Kraig
Make sure your shift cable is not kinked or bound up somehow and check that the selector switch attached to the trans is not damaged or the connector is not janky in some way.
Dnozgodlike
