Complete Lighting/LED List
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Unscrew for screws holding the assembly, carefully remove module and you will find the bulb socket on the back. Turn them slightly and pull out.
98chubby
I'm sorry about that i was reading the wrong part i'm an idiot! yes me!lol. It's 1157 that i really meant. My question is do the leds from superbrightlights come with the dual for the blinker and running lights? Also do i need any resisitors? thanks
SunlitComet
OBS Jedi-Do Good
1157 are dual circuit. You will either need load resistors or a led compatible flasher for the turn/hazard signal circuit. Each one will be a separate cost. Go with a flasher unit you only need one for the whole system and not multiple resistors which just take up space. My specific setup had resistors already installed front and back. With the flasher replacement I cut and removed them all for a true "energy efficient" conversion. The flasher for should be good for turn and hazard.
the big blue bus
richmond, va
what mm dome lights are yall using? the last time i ordered some they were too long 42mm i think. i measured the bulb and its like 38 mm i think. got some hp white leds off ebay the are sick. 10 for 10 bucks lol bright as crap got em in doors under dash and dome lights. got 10 blue comming as well for guages. started with the single led blue then the 5 now hp5 hope they do the trick
BamaDogg
What style is everyone using in their floor shifted, glove box, map lights, etc. All are 194's. What about dome lights?
99boxhead
cin,oh
wanna order my leds today. I got a question tho, can you change the needle color?
99boxhead
cin,oh
got em in
Eddiec32
