??? Console ??? 99 2 Door Tahoe
99Yuk
Northern Ontario, Canada
picture.php
I ran the wires behind the drivers side pillar and under the front of the headliner.
Sorry for the newb question, but how you get the driver's pillar off? I tried to one day to run the mic for the radio's bluetooth phone system, and I couldn't get it off. I was worried about breaking it so I stopped and just have the mic wire loosey goosey. If I run switchs up there, I'll need to run four or so wires up there. Is there enough room?
BTW, those gauges up there look really good. Nice job on the fibreglass.
---------- Post added at 07:50 AM ---------- Previous post was at 07:48 AM ----------
I didn't seperate the material from the headliner if that's what you mean? It's flexible enough to where you won't hurt it tucking a few wires underneath along the front...
Is there enough room for at least four or five wires?
steamroller
The South
The pillar is just clipped in there, I start by popping it out at the bottom and working my way up. Up towards the top it slides in behind the cover for the area in between the doors IIRC. Just take your time, I've had mine out several times with no issues. The plastic they used isn't like some of the older stuff that just breaks in half when you remove it.
Plenty of room for 4 or 5 wires up there. Just don't go crazy yanking on it :), a plastic putty knife or something could be used if you're really concerned with it. I just pulled it down slightly with my hand and pushed the wires in there, having the a-pillar cover removed makes it much easier to pull down. Thanks for the compliments :Handshake:
Gzes
the drifting 2dr
Wichita tx
Thats nice. I would probably run a cb or a scanner or sometiing like that in there but as of now nothing
Kramlik
Kramlik
IL
I Still Haven't Done Anything With The Overhead Console Yet i Have been Trying To Look Into Moving My HVAC Controls Up There I Know The 4 Doors Have The Control That Fits That Slot But I Am Unsure How The Wiring Would Work ? Does Anyone Have Any Ideas Or Knowledge About How The wiring Would Work For That Please And Thanks guys
Djohnson99
