Control Arm and Ball Joint Assembly
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
M
mnjeepmale
Thanks for the info. Do you think it's worth spending a little extra for the CK series(problem solver)?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
The problem solver items are for a rig that has trouble getting the alignment within specs after parts replacement. Those would be needed for a rig that gets an alignment reading before the parts replacement and sees that even with new stock parts the alignment will not be able to be adjusted to spec. Usually with weird size tires or known wreck damage but no frame repair has been done. Lots of times they are not installed till after new OE parts were installed and cannot get the alignment in specs.
QDaddy
I've done just the ball joints and screw that. My last two were control arm assemblies and I never looked back.
M
mnjeepmale
Well looks like I have aluminum CA after we put the truck in the air to replace the parts. Now to find the correct Moog parts to order.
91RS
GA
When I replaced mine they were Aluminum but the factory replacements are upgraded to tubular steel,no more Aluminum ones.
They're actually stamped steel. The ball joints last much longer on the stamped steel ones by the way so it is an "upgrade" in that aspect over the aluminum ones.
M
mnjeepmale
Well if you have aluminum CA it's replaced with stamped steel now according to the dealers that I spoke to.
They suggest to replace the brake hose too.
Rome58
