Control Arm Compatibility
OR VietVet
Multnomah Falls
Military
Willamette Valley
As @915_Tahoe said, straight swap. I would run with it as per @915_Tahoe said.
The arm should look just like the aluminum ones and bolt right in and make sure the alignment is done and post the before and after readings after you do.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Also states when replacing arms must also replace the:
LINKS L/R GM#23237268 $43.82 ech
LFT Brake Hose GM#84331227 $22.42
RHT Brake Hose GM#84331228 $22.42
BUMP Stop GM#84128120 $3.68
but customers don't.
91RS
GA
The ball joints in the aluminum arms are garbage and very often fail in the 80k-100k range. The ball joints in the stamped steel arms are failing much less.
91RS
GA
PG01
Up here to the right
so alum balls suck?
daddy g
