Coolant lake hours later
mijohnst
I'm thinking my water pump is going out, but before I go through all the effort, I want some other opinions. While it's running, there's nothing leaking from the cooling system. A few hours later there's a puddle on the ground on the front part of the engine on the passenger side. Water pump? I've taken the skid plate off, and I don't really see you spot where it's coming out. It is antifreeze though. What are y'all thoughts?
mijohnst
mijohnst
And I see the typo in the subject. It's not really a lake under the car, more like a small pond. ;)
drakon543
could be a waterpump they have a weep hole that might not leak when the pump is spinning. it could also be something else due to expansion and contraction with the heat.
get under it with a flashlight and look up, could be radiator, radiator hoses, heater hoses, coolant reservoir. heater hose "T"s, one heater hose has a Y those can crack also.
to see under the water pump you have to get at the right angle or use a mirror. other suspects (less likely) is the crossover steam pipe or intake cooler line if equipped.
Bill 1960
Testing the Limits
If it’s a shy leak, wrap a dry paper towel around suspect locations or just below, right after you shut it down hot and it sits and heat soaks. Come back later and see who’s got a wet diaper.
I also use a radiator pressure tester at times, but some leaks are related to thermal expansion of parts and they won’t show up under other temperatures.
Fless
Super Moderator
Elev 5,280
While it's running the leaked fluid may be blowing off or drying, so it may appear to be leaking only after shutting down.
AN292
I had a water pump leak that I never really pinpointed exactly where it was coming from. I just knew it was the pump, could be whats happening here. It helps to remove your upper fan shroud and air intake to get a really good look.
Also, the leak on the ground could be from the fluid running along a bunch of other stuff before it hits the ground, not a very accurate way to pinpoint the exact source of the leak.
treehan77
TYF Fiend
Crestview, FL
Borrowed a pressure tester from advance auto for free when I suspected the lake under mine was water pump. Yep, it streamed together out under pressure, like fire hose
rhammond3
