I have a 2002 Yukon XL 5.3 and I've been having a coolant leak the past few months. My water pump was replaced about 40,000 miles ago and doesn't seem to be leaking from that same area. Although I've heard stories about the gasket going slightly bad and the coolant just runs down the block and drips from the rear end of the block making you think that's where the leak is coming from. Anyways I'm going through a gallon of coolant every thousand miles or so. It's all over my garage floor, originating from the mid to rear end of the block. I've gotten it pressure tested several times to try to find the leak but no such luck. It seems like the leak might be coming out faster so maybe it'll show up with a pressure test now. But just looking for some advice from you guys. Appreciate anything you come up with.
