Coolant Question
tahoetoledo
Hey Guys!
How do I flush the coolant my 2003 Hoe?
Also, until I do.....can I add 50/50 coolant into the reservoir?
There's pinkish (Dexcool?) stuff in there now and I hear that it's best if you flush out the system and use regular green coolant.
hassoun
Germantown, MD
Only use DEX-COOL(R) if the vehicle was originally equipped with DEX-COOL(R).
Contamination
Mixing conventional green coolant with DEX-COOL(R) will degrade the service interval from 5 yrs./150,000 miles (240,000 km) to 2 yrs./30,000 miles (50,000 km) if left in the contaminated condition. If contamination occurs, the cooling system must be flushed twice immediately and re-filled with a 50/50 mixture of DEX-COOL(R) and clean water in order to preserve the enhanced properties and extended service interval of DEX-COOL(R).
After 5 years/150,000 miles (240,000 km)
After 5 yrs/150,000 miles (240,000 km), the coolant should be changed, preferably using a coolant exchanger. If the vehicle was originally equipped with DEX-COOL(R) and has not had problems with contamination from non-DEX-COOL(R) coolants, then the service interval remains the same, and the coolant does not need to be changed for another 5 yrs/150,000 miles (240,000 km)
Equipment (Coolant Exchangers)
The preferred method of performing coolant replacement is to use a coolant exchanger. A coolant exchanger can replace virtually all of the old coolant with new coolant. Coolant exchangers can be used to perform coolant replacement without spillage, and facilitate easy waste collection. They can also be used to lower the coolant level in a vehicle to allow for less messy servicing of cooling system components. It is recommended that you use a coolant exchanger with a vacuum feature facilitates removing trapped air from the cooling system. This is a substantial time savings over repeatedly thermo cycling the vehicle and topping-off the radiator. The vacuum feature also allows venting of a hot system to relieve system pressure. Approved coolant exchangers are available through the GMDE (General Motors Dealer Equipment) program.
etreanor
