Copper&Black's Complete Custom Build Thread
Copper&Black
Copper&Black
Little tease on what I'm wiring up right now, and it will give you a good outline of the speaker system. The front speakers are going to be in kick panels, then front and back doors sets, and then the last two in the back hatch. Wired with 16 gauge monster speaker cable, and run seperated from any power cables.
Copper&Black
Copper&Black
Yup yup crossovers, they seperate the high and lows to the tweeters and woofers. Actually just came on to post a pic of what I did to all the crossovers. I put some silicone in the corners of the crossover housing. You don't want that board falling out of it's clips on a hard bump and rattling around in it's housing behind your door panel.
---------- Post added at 01:18 AM ---------- Previous post was at 01:15 AM ----------
sick install on the Dynamat..... check out Fat Mat cheaper and same quality!! comes in a roll, so its easier to lay long strips!!!
Oh well, I need less then a box to finish it off, and I'm not changing over now. Thanks for the info, maybe I'll look into that for my girls car.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
cheaper yes.
quality, no
Sorry, but Fat mat is nowhere near the quality of Dynamat Extreme. Nor does it work as effectively to start or later down the road.
Both the adhesive, the rigidity of the foil backing, and even the thickness/weight compare unfavorably to Dyn Extreme. it IS better than the old Dynamat asphalt, and other asphalts...
The best out is Damplifier pro IMPO, and regular damplifier and dynamat extreme are about equivalent... the price for Dyn Extreme on Amazon is about the same as the price on SS Damplifier, so price they are both a wash and both a great deal.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
Dyna as a company is awesome. I have never used them in a car, But I must have spent an easy 50k using it all over my house when I redid it. its So go you can never tell it storming out until you open a door. I got dynil in the walls. and Dynapad on the floors and ceilings, in every room, Including the garage.
BlizzardX23
Sacramento, California
How much Dynamat is used for the rear floor section? I got 1 bulk pack of extreme (36 sq ft)...will that be enough to atleast get the cargo floor area for now?
Copper&Black
Copper&Black
For just the cargo area floor that will be enough, with a a piece or two left.
Here are a couple pics of today's work, finished off wiring from the front two door and placement of the wiring harness, power cables and speaker cables in the channels of the front doors. All connections have been coated with electric greese/oil. Not much but keep in mind it's football day...Go Cowboys!
jrsmyre
