MadMax_MFP
Hi All, after doing a lot of research I have found several part numbers for my 2018 PPV carpet swap. Hopefully someone here has a better insight to the GM part numbers before I order.
The first thing I did was obtain the rpo codes for my vehicle but oddly enough the QR code does not show all codes. For example no G80 listed or rearend code which I found odd as the older vehicles with the sticker in the glove box had all codes and I could refer to my rpo code book for the descriptions.
Ok, back to the carpet. I'm going for the black carpet pieces as the Tahoe carpet is three separate pieces. I am keeping the rear the PPV vinyl and added a WeatherTech mat since I transport blocks, heads and rearend parts often when doing builds. I have found 4 part numbers for black listing 4 panels, assuming for the front carpet section and 4 part numbers for black intermediate section (second row).
The 4 front part numbers are 84118407, 84118396, 84118395, 84118394 (replaced 23309092) and 84118398 (replaced 22913565).
The 3 intermediate numbers are 84355015, 84355018, 84355023 and 22913572.
Each part number listed has a small list of rpo codes which 1 or more of my codes are listed and some list excluding rpo codes.
Any help would greatly be appreciated. I realize that since my 2018 is a PPV the vin and rpo codes will say the parts do not fit but I am sure their is a set the will fit with minor mods due to the 40/20/40 seating I have in the vehicle. My guess is the carpets have minor variations based on seating (bench vs captain chairs) and which console, if any, is installed.
Thanks again in advanced.
