Corsa 6.2 Available
WYO-HD
Did you have to cut the stock one out?
The 4x4 shop that installed my lift also installed my Corsa. They indicated they just cut behind the muffler, pulled the aft section out behind the axle and unbolted clamp at the cat for the front part. Went back in bolting new flange up to cat and piecing together from front to rear hand tight. then once everything was aligned and in place, tighten to spec from front to rear.
Niz181
Finished my install yesterday and you definelty have to cut the exhaust out and lower the spare tire
Regulator23
