brad6603
Hey guys just wanted to let everyone be aware of my problem with the corvette servo. After reading on this site about them i picked one up off oregon performance on ebay and installed it in my 2001 Tahoe 4x4. I ran the servo for three months with no problems and everything seemed fine. That was until Friday morning on my way to work. It was around 40 degrees and i was driving normally when i noticed that it wasn't shifting into overdrive. I came to a stop and then took off again and noticed it was not shifting correctly. Thats when i saw the smoke pouring from behind me. I immediately pulled over and looked under the car to see trans fluid gushing out. I turned the car off and called a wrecker that took it to my chevy dealer trans shop. On the rack we looked and the case under the servo area was busted. It was just a huge crack. I told the techinician about the corvette servo and he simply just shook his head. He said he has seen this many times. The case is weak at this spot and cannot take the increased pressure. He said that he has been running a corvette servo for 2 years in his truck with no problems but the other technician had the exact same thing happen to him. So beware folks putting the corvette servo in your daily drivers. I learned from this expensive mistake and will never do it again. I will post pics when they pull the case out of the tahoe.
