couple of basic questions
clownracer
1. what size is the nut on the 4wd actuator (my adjustable wrench dosent fit it)
2. what is the torque for the bolts holding the waterpump to the engine edit: 454
3. how the heck do i break the fan bolts loose without air tools?
purple 'hoe
Green Bay, Wisconsin
No idea what vehicle this is for, but I'm going to guess it's for a OBS Suburban 2500
1- No idea. I'd just use a slip-joint pliers to loosen it
2- 30 ftlbs
3- Gonna wanna use air tools on that. I don't really have any other way
C
clownracer
2- 30 ftlbs
thanks it is a 94 yukon with a 454 out of something in it its a tbi engine
slip pliars arent gonna work here someone monkeyd it on tight
electro
Kitchener, ON, CAN
I read...
Hold the pulley with a strap wrench and than use a large wrench to remove the fan clutch nut. Of course you will need to remove drive belt to do that. Add 2 minutes.
Oops, didnt read that until I posted. Dont know anything about that engine set up, I assume its similar.
retorq
Kingman AZ
The year of the 454 matters, the old stuff I've always been able to use a long closed end wrench, put it on, give it a switch smack and the nut should break loose. If it doesn't you can typically get it into a position where the force you apply isn't' trying to turn the pump and fan just the bolt ...
Donnie Yukonie
Yates Caretaker
i left the belt on and as stated give it a swift smack for breakaway torque , or option 2 drain oil start vehicle floor it until engine seizes and then it wont break away .... kind of my Al Green humor attempt
kaoticlife
Port St Lucie, Florida
good strap wrench, adjustable wrench and a hammer! the loan a tool crap at autozone didnt fit so thats finally how I did it. If you go with a lincoln mrk8 electric fan you wont have to worry about doing it again (changing the fan clutch that is). :alone:
Elio_vega
