Courtesy door lights
bankswood
Don't know what they Are actually called but thereis one at the back of each door panel. They have a lens that is half clear half red. I would like to replace mine. Does anyone know where I can find them?
big_b_in_PA
Billy Badass
Central Pa.
The lens or the bulb? I think the bulb is a 194 or equivalent. The lens can be found on eBay pretty easily.
Rivieraracing
Never thought of looking on Ebay, what would you call them, wanna see how much I can get them for on there!
big_b_in_PA
Billy Badass
Central Pa.
Well I couldn't tell you what they were called, but courtesy door lights may work.
Good luck!
B
bankswood
Holy S@#@... $60 each. Thank goodness they don't fit an 01.
chauncey0337
MLT, WA
$60 for the pair. And as far as I know, they should fit 2000-2006, but what do I know. Can somebody confirm this? Although, on mine I remember the wires were hard wired to the socket. But if you know how to solder, it should be an easy retro.
B
bankswood
The compatibility chart on ebay says they will not fit. Also they look longer than mine in the pic. My bulb socket pops out of the reflector so replacement shouuld be easy. I replaced all my interior lights with LEDs (thanks Chauncey) and I just want some fresh lenses.
OkieBS
