crank,blocks,and raise rear bumper question.
felskee
how much should you crank? and could someone post pics of a 2 door with a crank and bl? and second question is how to raise back bumber after bl?
96ProCompTahoe
IN
Back bumper you will have to either make brackets or cut up whats there and have it welded up higher. no aftermarket brackets out there that i have come across (or anyone on this forum so far) for the 2-door rear bumper.
the big blue bus
richmond, va
i have brackets on mine... zone offroad sells them.. on the 2dr though with gas tank out back i think id show too much.my buddys is stock with different than stock hitch and thr gas tank is ugly
Drumrunner
West Palm Beach
I have the zone kit on my 2 door and it looks great. I have the stock hitch so you really can't see the gas tank but if you could its painted black anyways.
felskee
felskee
can yall give me a link to the kit for the bumper
96ProCompTahoe
IN
I stand corrected, i have read several places that the kit would only work on the 4-door trucks because of the gas tank or frame rail ends were different.
have to cut or do anything other than bolt the brackets on? Pics?
Drumrunner
West Palm Beach
Yes it is for the four doors. The problem is that the rear spring hanger on the 2 door is in the way. I called Zone and talked to salesman and the tech department and told them what needed to be done. The mounting point that goes over the bracket needed to be cut off. I didn't want to do anything till i made shure with them. (Zone is a top notch company in my book) The tech department called me back and told me that they tested my idea and it would not hurt the integrety of the part and to go ahead and modify it and it would still be warrantied if something happened.
the big blue bus
richmond, va
pics for you... my hitch is off right noww. can get pics if you want too. oh also attached a pic of 3inch bl with 2inch blocks and like 1.5 inch crank on 245s going to be on 33s on some 15x10s in the next few weeks
L5Pdenali
