I just bought a 2003 Yukon with 126k. I know it has an oil leak and coolant leak. When I start the car the oil pressure goes straight to 80. For the first minute or two of driving, when the car is about to shift the pil pressure will go down to 0. Once it's shifted it will go back to 80 and bounce around some. After a minute or two of driving it will stay at 80. There is no oil level low warning.
Also the coolant is leaking. Would this just be a leaks in either the radiator, hose, or coolant container. Or does the coolant go into the engine at all?
Lastly, it takes two turns of the key to start the car. The first turn the car tries to turn over but it seems like the battery is low. The second turn starts it right up and a whisp of smoke comes out of the exhaust. My battery gauge is at 14 and the connections are solid. Is this a spark plug issue? dying battery?
Thanks!
Thanks!
