Cruise control stopped working.
99Vortec
Did the obvious and pulled fuse #6 and replaced to no avail...
So it must be a problem with either the Multistick, the brake switch, or cruise control motor/unit itself?
The brake switch was replaced a while back, so I am guessing but not convinced that it is not the culprit.
I am thinking it might be the multistick, as the "coast" end button appeared to be stuck when I first noticed the problem. But does anyone have a meter test procedure to check for proper multistick cruise control switching operation???
I'll bet the part is ridiculously expen$ive new...
Thanks.
Parthery
Atlanta, GA
Did you check the brake light switch? Very common problem and if the switch needs to be replaced, it's only about $25 or so.
shortbusondubs
I was going to suggest the same thing, but wasn't sure if it was a common issue in the pre 07 models.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
for testing.
  • gmt400 cruise control diagnosis.pdf
  • gmt400 cruise control electrical diagram.pdf
99Vortec
99Vortec
Thank's for the info. It's working again. Problem looks intermittent for now.
Mayhem
Had the problem with my wipers.
Tried the motor first
Wasn't it
Tried the multi switch
Wasn't it
It was a single wire from the inside to the motor -.-
starhawesjr
