current issues
the big blue bus
the big blue bus
richmond, va
i will try that first since its the cheapest and really makes the most since. it only acts up when tis cold once its warmed up its all good. ill replace it when i get some money this weekend
gpracer1
Phoenix
You could put an ohm meter on the cts and check what it reads at both cold and engine warmed up. I'm not home to check my manuals, but I'm sure someone here can reference the values in the shop manual for you.
I'm actually guessing it may be reading high.
the big blue bus
the big blue bus
richmond, va
if somone could get me the numbers i could do that. but i havent been able to find a chart on what the resistance should be based on temp. after i cleand the iac the idles lower now still has the stumble problem till its warm.
bobwass
