CV Axle boot torn!
redeknightjr
Hey anyone can you help me? This evening I installed DJM upper control arms with the removeable ball joints! I love the set up. Here is the problem the instructions called to put 2 washers between the castle nut and spindle. Upon doing so it left aproximately 1/16 to 1/8 of an inch between the castle nut and cv boot edge. I had to loosen the cv bolt and slide the axle in approximately an inch to install the nut. (No space to work). Wellll, i took ot for a test drive and upon return the boot was completely detached. Can replace just the boot? If i need to replace the complete cv axle is there an upgrade that will be better?
Sent from my SM-N910P using Tapatalk
08grey
You can take the axle to be rebooted. Grind down the nut.
02Burgundybeast
South GA
Just replace the CV. They are $90 from autozone and take 30 minutes to swap. The hassel of putting a new boot and greasing it up is not worth it.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Yup. The cost in labor to replace the cv-boot + parts is almost the same as replacing the whole axle-shaft. Just get the whole cv-axle and do it yourself.
redeknightjr
redeknightjr
Thanks gentlemen, I already replaced it and will be doing the other side tomorrow
tahoe_highcountry
