Dam thing won’t start!!!
Alexquade
Crowley, LA
I THINK that year gm, the keys can be reprogrammed by leaving the key in the on position for 10 minutes. Absolutely no less. Turn the key on and set a timer. Worked a 2000 old body Tahoe limited. Or 99. I don’t remember.
inmypassatlife
I dont think there is a transponder in the keys.
Thats not what I said, but keep running around looming for an answer...
The sensor is in the ignition housing. It is only triggered when you rotate the key cylinder, when the magnet in the key cylinder activates the sensor then it send signal to the BCM
RET423
I vote for an issue with the VATS as well, they get glitchy when the cylinder housing gets old.
rockola1971
Indiana (formerly IL)
You replaced the ignition switch, but did you replace the switch housing? That's what has the sensor in it.
Replace the housing and relearn the keys, if that doesn't work, then replace BCM
As quoted above, you said that the keys would need to be relearned and that just is absolutely not true. There is nothing within the key for any sensor to "relearn". So keep making up stories and maybe one day you will get lucky and will be true.
I’ve tried rocking it when it doesn’t start. That doesn’t help. I’ve replaced the ignition switch. When it won’t start it legit does not make a sound. No click nothing it’s dead silent
is the "security" light flashing? when it does the no start?, normally even if that was the problem it would start and die start and die, but you never know I've seen weirder things before.
JetBlackNali
Vancouver Canada
The wifes 99 slt did the same thing. I was so pissed I slammed the drivers door and heard a CLICK. Wife reached through window turned the key and it fired. Turned out to be a bad ground.
memphizhoe
So did you ever find the problem ? I’m having the same issue. 05 Tahoe . Just curious .
antennabob
