Dashcam
Mr.Jack
Norway
I am trying to install a dashcam. But the 12 volt power outlet continues to deliver power when the truck is shut off.
What to do?
Where to can I connect the dashcam, so it will turn off when the ignition is switched off?
Mr.Jack
Mr.Jack
Norway
What do you mean by another key on hot surface? (I am an alien.) :)
08grey
Look for a item powered by accessory (ignition) to tap.
YukonXL04
The Riverboat
Arlington, TX
In your fuse box under the dash on the drivers side look for SEOACC (I think 2) and use that for power.
clandr1
Dallas/Fort Worth, Texas
you said surface, but i think you meant source, which is what i said.
basically, you need to find a 12v source that is only "hot" (providing voltage) when the key is turned to the "on" position.
then, use that source as a signal input for a relay. that way, your dash cam is only operational when the key is in the "on" position.
01TX_Tahoe
Semper Fi
Pasadena, TX
12volts red + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ignition harness
Power Lock lt. blue + pin A4, brown plug at BCM
Notes: The BCM (Body Control Module) is located behind the driver side of the dash. The plugs face towards the rear of the vehicle.
Power Unlock white + pin A3, brown plug at BCM
Lock Motor gray 5wi driver kick, door harness
Unlock Motor tan 5wi driver kick, door harness
Parking Lights+ brown + pin B6, lt. blue plug at BCM
Parking Lights- white - pin A5, lt. blue plug at BCM
Hazards same as turn signals
Turn Signal(L) lt. blue + steering column
Turn Signal(R) dk. blue + steering column
Reverse Light lt. green + inside rear view mirror
Door Trigger - BCM
Use tan for the driver door located in pin B4 of the purple plug, and the passenger doors are a blue/white in pin B11 of the lt. blue plug. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin pink/black - pin B10, lt. blue plug at BCM
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock
Factory Alarm Disarm lt. green - pin B3, purple plug at BCM
Disarm No Unlock see factory alarm disarm
Tachometer white ac ECM
Notes: The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector
Wait to start dk. blue - instrument cluster
Brake Wire white + brake pedal switch
Parking Brake green/white - parking brake switch
Horn Trigger black - pin A9, brown plug at BCM
Memory Seat 1 white + memory mod under dr seat
Memory Seat 2 purple + memory mod under dr seat
Memory Seat 3 N/A +
