What is P0563 (Ignition Voltage above 18v) - And why does my car not AUTO-STOP?
braveheartwallace
braveheartwallace
An update after visiting the GMC/Chevy dealer in Monahans:
They were no help at all. After waiting for 6 hours a tech came to me and said "You need a new AC/DC inverter, your's is completely shot. Parts will be $5000, labor $7000, how do you want to proceed?"
I asked what DTCs they read and what tests were performed to diagnose that. He didn't have any new codes aside from what I told the dealer I found with ignition voltage. I asked him how he was sure the inverter was INOP. He said thats what their tests concluded. I share that if the inverter was compeltely non functional it should throw several DTCs. Additionally, with no inverter functionality, you would have no engine crank, no AC compressor, and no power steering. All of which still function on my car.
The tech looked at me like a deer in the headlighs and exclaimed "I didn't realize you knew that much about the car. I'll go run more tests..."
After 2 more hours the service manager came to me saying "the tech's aid you need an inverter, $5000, $7000 labor, blah blah..."
I asked the service manager if they did any further diagnosis in the last two hours and he didn't know. We then tried looking for the techs working on myh car and were unable to find them anywhere.
I towed the car home to San Antonio with a uhaul flatbed and have begun working on it in a limited capacity.
I have disconnected the 12v battery and shorted the + and - termiamls for about 3 days. I started the car and it ran and drove fine for 3:55 seconds before shutting down. Again, no check engien light or DTCs, but this high ignition voltage error is in the history. Planned next steps are to disaseble the high voltage battery, check all cells with a multi meter, and double check all HV connections and sensors.
j91z28d1
yeah the dealer completely lied to you, but if you needed an inverter. I've seen them for either 500 or 800 on ebay. not hard to install. there's a youtube video about removing one to work on but I agree it doesn't seem bad.
i forget, do you have a scanner to read individual cell voltages while it's running? that would be interesting but also it should throw codes like crazy. these seem to throw tons of codes even thou half of them don't help.
BG1988
if you're going to take apart the HV battery you will need linemans service gloves it has 300-340 volts inside of it
1GKS2GEJ82R
New here.
I would assume fuel is not a problem, but the randomness of how long the vehicle stays on before the issue occurs does sound like 1.) there is an issue that occurs 100% of the time 2.) The issue is not actively present until the engine is ran for some time.
Since you'd mentioned the code seems to indicate voltage issue of some kind and you've had the pack open previously to replace cells. I would suspect bad cells, maybe corrosion, maybe a bad ground somewhere in the system.
tom3
Don't know anything except basics but I'd get out the volt/multi meter and actually check voltages at the various spots. I sometimes take a needle and punch through insulation to get a connection if needed. Check for voltage drops through cables/wires. Code for high voltage would tell me there's an open or bad connection, I'd suspect the ignition circuit.
braveheartwallace
braveheartwallace
I've let the car sit for weeks now as I've been too busy to DIY anything and have been daily driving my more reliable 2001 Tahoe...
I'm going to start working on it again tomorrow. It is strange for it to still have no check engine light and throw no codes at the moment.
I do not have a scan tool that can see individual sell voltages but I have a GM tech two emulator. It may be able to do that, but I doubt it.
j91z28d1
your tech 2 will do everything needed. even a 5$ torque phone app will with the pids added and a 30$ Amazon dongle. it will log to an excel file if needed.
this is what my setup looks like. I check it every few days it so out of curiosity.
1GKS2GEJ82R
Hopefully you've made a full recovery on your hybrid, but if not... I'd start with checking fuses and ground points, probably want to clean up some grounds.
I would still suspect something that is active in the process of regen braking. What could happen in that normal process that would cause the system to shut down, and I assume, keep shutting down after the engine runs and charges up the pack?
Good luck, that's my hypothesis from 1000 miles away and via the internet.
rockola1971
Indiana (formerly IL)
A logical explanation of the randomness that the engine shuts down after starting right up is the fuel pump being run in a virtually empty tank (sump area) got really hot and windings in motor opened up. The windings make connection and engine starts right up and then eventually after windings warm up normally the loss of continuity from the initial winding opening up shows its ugly head again. I would do a fuel pressure reading before engine start, during engine running and when engine fails to continue to run. This will rule out the fuel pump for once and all. You might also want to inspect fuel pump wiring harness plug at tank as these are known to bake themselves too.
A bad fuel pump wont throw any codes when all gm had to do was put a pressure sensor on the fuel rail and give it an address in the PCM.
j91z28d1
These actually have a full fuel pump module. they don't have a fuel pressure regulator like the older stuff. these control pump speed with a DC square wave, so they have a full set of trouble codes, actual fuel pressure, target fuel pressure and the trim needed to hit the target. there's a theory that you might be able to chart fuel pump life off the trim needed if you could record it over time.
your tech 2 will show it all.
aph7649
