Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have not taken a new measurement with the .75" rear spacer, but twitch just 2" up front I was measuring 38 up front and 38.25 rear. So if the leveling kit is true to its size I should be somewhere around 39 rear, 38 front
The front is double the lift for the size of the spacer when spacer is on bottom of strut. Example 1/2" spacer is 1" of lift. For the rear it's true size so 1" spacer is 1" lift.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
