DDM HID Fog questions
DYRTIGAF
Does anyone have any installation instructions or installation pictures for doing the Fog Lamp HID Conversion? It sounds stupid but I am having issues getting the bulb out of the OE Fog Lamp. 2007 Tahoe LTZ
KissMyWhiteSS
Summerville, SC
I was having the same issue. If you look at the bulb, the outer ring that snaps to the back of the fog light housing is connected to the bulb...you have to pull the plug out of the back of it. But you need a small flat head screw driver the release the clip. the clip is down inside of the back of the bulb. you need to take your screw driver and pry it up then pull it out. The issue I had came from that plug not plugging into the ballast from DDM. if you have gotten this far how did you make this work?
THE YETI
Director of Operations
South FL
can't speak for DDM, but our spencerhids.com setup plugged right in.
Steeveyukk
