DDM hid question
Scotty
I see everyone saying to get the relay harness. All I see is the error code elimnator. Is this the same thing cause on other sites I see an actuall relay harness.
S
Scotty
I went with 35w 6000K for both my hi/low and fogs. I have an 07 Yukon.
bjc7jr
PA
The yukon kits already come with the harness. I was getting intermittent firing in my yukon and they said to disable the DRL's. If you have any problems, try that.
Conor
"Bob's your Uncle"
Seattle, WA
Nice, thats the best color in my opinion. Perfect mix of color and brightness.
Just be carefull with the fogs, dont run them for extended periods of time or when you dont need them. They will burn the inside of the housing if your not a little carefull. Take my word from it, I just replaced two housings and both bulbs. But, if you use them carefully, they will last a long time and look sweet.
Also, when you are installing the fog HID's, I found that it is much easier to sdeat the bulb when you pull the housing out of the bumper. Pulling them out is VERY easy, you dont even have to unscrew anything, they just pop out from behind. That way you can make sure the bulb is in there good, and to make sure you dont break off the tabs that hold the 5202 bulbs in.
S
Scotty
Thanks for the heads up. Is this a problem with all or just hit and miss. If so how do you disable to DRL's.
Appreciate the heads up. They should be in Fri or Mon. I'll have to install them when I get back. The sent them out quick. A few hours after I ordered them they sent me a tracking number.
Erebos
Are you using the HID with the original housing or are you putting this on the aftermarket housing with projector? I'm planning to do one on mine. I used to have it on the 4runner and it has the projector housing so it was nice, but not sure how it would look on the factory housing. I don't want to blind all the on coming traffic or be a jack@$$ and blind everyone in front of me :). Post some pics once you got them installed.
S
Scotty
I'm going to use the original housing for know. If it doesn't look right I'll get projectors. I had a '03 350z before my Yukon so I know how it feels to be blinded by everyone. I get home tonight so I'm hoping to have them installed tomorrow or Wednesday. I'll post pics though when I'm done.
