SLT Kon-Man
Conor, can you explain in detail how to remove the fog light housing from the bumper, I've always had to make a trip to the dealer to have a blown bulb replaced, and I'm almost certain they are doing the same thing you are talking about because it only takes them one or two minuites to change the bulb.Nice, thats the best color in my opinion. Perfect mix of color and brightness.
Just be carefull with the fogs, dont run them for extended periods of time or when you dont need them. They will burn the inside of the housing if your not a little carefull. Take my word from it, I just replaced two housings and both bulbs. But, if you use them carefully, they will last a long time and look sweet.
Also, when you are installing the fog HID's, I found that it is much easier to sdeat the bulb when you pull the housing out of the bumper. Pulling them out is VERY easy, you dont even have to unscrew anything, they just pop out from behind. That way you can make sure the bulb is in there good, and to make sure you dont break off the tabs that hold the 5202 bulbs in.
Thanks...
