Debating on lowering my ride
Max
Mile High
Denver
I have no issue getting to most campgrounds slammed on 2s
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Belltech kit uses spindles DJM uses keys.
Belltech makes shocks for both front and rear
DJM only does the rear shocks
Administrator
I believe he's asking the difference between the djm and belltech sway bars other than the price?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
belltech 1.25 front
djm 1.5 front
belltech 1 inch rear
djm 1.13 inches rear
2005SnowKon
2005SnowKon
Fort Collins, CO
Ah thanks thats good to know... Can you use factory sway bar links or do they come with new ones
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Stick dndlinks can be used but if you want shorter ones the DJMs are 85 and rellocate the bar over and keep it more parallel to the ground
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Gets rid of your stock items which are weaker and a lot of those 00-06 trucks rear bar rubber bushings are rotten so might as well change it
cpranger22
