Deciding what to do with my 2023 Denali
Jocko PDX
Portland OR
So my 2023 Denali is on the dreaded "engine recall list".. Sigh. The dealer told me that I would need to bring it in for an "inspection". Apparently if it passes the inspection I would get an oil change to the different viscosity oil and a new oil cap and sent on my way.. again sigh.. I paid $93K for this rig and have only put 9,500 miles on it in 18 months because I still drive my '03 suburban most days trying to finish it off (but it wont die). Obviously trying to sell my 2023 will be a huge bath as given the recall no one would want the rig. Luckily I am not in a financial position that this is a massive problem for me, but I also don't want to take a huge bath on it. I am considering trading it in or selling it. the news on this seems to show that there are 28,000 incidents out of 877,000 rigs so that is only 3%. Not bad odds I guess... Just looking for any and all advice on my situation. Thanks
Jocko PDX
Jocko PDX
Portland OR
Take the dealers inspection, and then decide.
My trust of this process is minimal at best. My understanding is that the engines are fine until they are not. I personally know 3 folks that have had their engines fail and there was no prior symptoms before failure
the 18th letter
Northern New Jersey
Sounds like the 03 is the dependable rig. Drive the 23 until the warranty expires, and keep the 03 on deck in case the engine does have issues and there’s no loaners available.
Jocko PDX
Jocko PDX
Portland OR
the '03 has 295k miles on it and has a bad transfer case. Its on its last leg.. It seems like it might be smart to dump the 2023 before it has issues unless the likelihood of a bad engine is low. I'd really like to understand the likelihood of that..
the 18th letter
Northern New Jersey
I don’t think there’s anyway to predict it unfortunately. Selling it while there’s some warranty left could help the sale.
KMeloney
Where'd you get these numbers? If the lower number is the number of known failures, and if all of the failures had occurred, say, under 10,000 miles, then I'd feel good about the odds once I got over 10,000 miles. But these are failing at various mileages, so there's no reason right now to believe that the failure rate isn't 100% "over time." And that leads me to believe that these failures aren't the result of a bad design, but rather a batch of bad parts.
If all of the failures are ultimately deemed the result of a bad run of supplied engine parts, and I can more or less be guaranteed that any engines built after a certain date are fine, then I'll be interested in having GM replace the engine in my '23 and keeping it. I still prefer the look of my '23 Denali to that of the '25 trucks.
Jocko PDX
Jocko PDX
Portland OR
I have no issue with the rig. I really like it. I am just not wanting a rig that could fail at any time. I will be regularly be pulling a 5,000# boat on windy mountain roads in Oregon that have no shoulder. I don't want to be concerned about it. That is where the math comes in.. If I new the likelihood was low, I could live with it...
