DefendHawaii's 99 Tahoe build
DefendHawaii
DefendHawaii
Snake Eater
Kahala HI/ Seattle WA
Debadged the back logos last night while at the car wash. Also trying to patched the muffler for a temporary fix. Looking at options for a budget exhaust system. I wanna just go dual out with cherrybombs and then do good looking dual tips on each side.
DefendHawaii
DefendHawaii
Snake Eater
Took 2 afternoons for some stupid reasons but finally got my HID's in 6000k for my lows all set up. Since I use Crystal Eyes projector housing had to rig it up with a relay. The bulbs are 35w H3 bulbs I spent 50.00 on the kit and got my relay harness free. The wires are mounted different since I could not fit relay onto the battery they are attached to the fuze box relay and then the neg is grounded to the frame. Was a bot of a hassle all together but now I see how it works on chevy vs Jeep. I am waiting on all my new lighting stuff and my bullbar was told 3 weeks for the bullbar and 3-5 for all exterior lights.
DefendHawaii
DefendHawaii
Snake Eater
Ok so today I was able to finish my heater core project. I spent about 75.00 total. I had to get a new heater core, heater valve, 2 rubber hoses for the core to valve, and a set of vice grips.
I noticed my check engine lights off! I think I fixed it when I replaced this damn core!
Took me about 2 hrs total. I had to learn as I went basically. But it is easy to do. Just had to remove the air filter and box to get some space. Un clamp all the hoses and remove them from the valve. Unclamp from the core exit spots. Now this part was hard my hoses were practically glued to it. Could tell from the plastic on the valve that the core was the original from the factory. Plastic in the valve was brittle and old feeling.
Installing the core just open the black box in passenger spot and I tossed it in their. ake sure your clamps are all on the tubes and got them all dialed in and on. Reinstalled the airfilter and box. Started it up and it sounds great! I need to go and grab some DexCool now and get it topped off.
Next thing this week is the heater control inside the truck. None of my knobs work!
Oh and after fixing the core, My check engine light is now off...
DefendHawaii
DefendHawaii
Snake Eater
The new heater core, hoses, and heater valve.
DefendHawaii
DefendHawaii
Snake Eater
Some new upgrades. Need grab a smaller oil filter wrench today. One on now is oem crap! And stuck on. Got the wipers for 7.00 per and back one for 5.00 at the PX.
DefendHawaii
DefendHawaii
Snake Eater
Got a new dual in single 3" out magnaflow installed. Also finally got the heating and cooling issue resolved. Went down to the wrecking yard for a second time exchanged the one they sold me and got a good heater control panel.
car_lost
good stuff. sub'd for more updates :)
saw your cima. are you on vipstylecars.com?
DefendHawaii
DefendHawaii
Snake Eater
Right guys here is a few photos. Got the Magnaflow installed dual in single out.
Sorry photos suck using an iPhone underneath the Tahoe doesn't give me much room.
DefendHawaii
DefendHawaii
Snake Eater
An this is my 6000k HIDs in the highbeams.
Not bad definitely
Better then just standard halogens. Will be using 3000k bulbs in there once I get my 4hi mod also the corner lights are LEDs also
mohammadamlih
