Demon possessed heated seats!
S33k3r
Dallas, Texas
So I replaced the heat switch with an oem part and the heated seats still cycle on and off. I also hooked up the tech2 to the door module and I get no codes. Wtf
What does the heat switch plug into?
rgosart
Thats because the problem is not the heated seat button, its either the window switch or the heating pad. Most likely the window switch or DDM.
ivin74
05 NBS Nali
Htown, Texas
Did you try turning them on and off and if adjustable, doing that with the Tech-2?
I will try that today.
It plugs into the window switch
My next option is to buy a new heating pad. If that does not fix the issue, I will buy a new window switch.
smcnair
It is the window switch that controls the windows and mirrors. Replace that part and all will be solved.
rgosart
@smcnair
How sure are you that is the problem?
If you disconnected the heating pad and the problem still exists I am about 99.9% sure. Even without trying that I am about 90% sure the window switch is the issue. It is very common.
S33k3r
Dallas, Texas
What I have read elsewhere -- and no, I do not have a link -- is that the circuit board on the switch gets coated in dust from exposure to the elements. Then, when there is enough humidity in the air -- especially rain! -- the switch shorts. I've experienced this in a Silverado when it was 95+ degrees outside and a million percent humidity. :eek:
ivin74
05 NBS Nali
Htown, Texas
I disconnected the heating element and it still does it.
I'm going to bite the bullet and buy the window switch.
S33k3r
Dallas, Texas
I have heard that if you simply clean it, you are good for another year or two. The sole caveat being that your switch isn't already in a constant state of flux. If this is intermittent, then the dirty circuit is likely your gremlin.
It is still a good idea to look into replacing the heating pads on the seat, since they are, at best, 14 years old (can't remember your model year, sorry).
Lfryklu
