Yep. This.When you turn the key on, is there power in the vehicle? Headlights, horn, etc and just won't crank until you hit the key a few times? If that's the case, it sure sounds to me like a starter solenoid is going out.
How do i figure out/fix this.Corrosion at starter...
It's most likely the starter solenoid. I don't know if you can change just the solenoid from the starter on these or if they are one unit with the starter itself. Try tapping it with a hammer first.
I would say it's not the ignition switch if your lights and radio dim when you hit the key to start it. That's current draw from the starter. If the ignition switch was flaky the lights and stuff wouldn't dim down.
That is completely inaccurate in reference to the ignition switch.
