Denali Cluster
alex s
A while back I replaced my cluster with one from an 04 Denali. I replaced mine because half of my lights were burnt out, no PRNDL, and I wanted a trans temp gauge.
The denali cluster has a "personal miles" and "business miles". When I first installed the cluster I set these both to zero, and they are still at 0. Is there a way to get them to work? Or do I need to just accept that they never will?
alex s
alex s
The cluster needs to be programmed? Any idea where I could get that done? Or possibly do it myself?
I have the same issue with my Esky cluster in my Tahoe. I had it completely rebuilt with my mileage programmed into it too.
adventurenali92
Big Bear Lake, ca
Usually speaking getting the correct mileage programmed into a cluster requires sending it to a company that the correct equipment to do so. Like US dash works which is the tech who used the be the cluster guy for digital dash solutions. He know what’s he’s doing and they’re customer service is off the charts phenomenal. That’s how I ended up getting my escalade cluster rogrammed to my denalis correct mileage. The only sucky part is that you have to ship it out to them. So truck has to sit in order for the mileage their erogrsmmkng in to be accurate.
It doesn't really have to sit, it'll still run and drive without the cluster--but I get what you're saying.
alex s
alex s
Thanks everyone, I will probably just continue to use the odometer to monitor my trips. As far as mileage, it really doesn't matter to me, as I will probably be the last person to own the burb.
BigBodyBurban
