Denali headlights
ezdaar
Chat Troll
Redneck central, Aka Houston
Spyder and spec-d brand from amazon or ebay are very very VEEEERYYYY easy to retrofit with a kit feom retrofitsource and will give you susbstantial amount of useable non offending light.
Second and third row.
http://www.theretrofitsource.com/complete-retrofit-kits/application-specific.html
Pick your choice of headlight asemblys feom one of those brands and get that kit.
Dig deep enough and you will find matching turn assemblys.
Fyi, there a ton of pem denali headlights on ebay right now.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Spyder and spec-d brand from amazon or ebay are very very VEEEERYYYY easy to retrofit with.
Thanks for showing up in here... Help him find the way
YukonXL04
The Riverboat
Arlington, TX
I can confirm how easy the spec d lights are to retrofit. It was my first one ever. I made my own projector mounting plates and used generic h1 projectors. I will say the housings are kind of cheasy. The housing itself doesn't adjust so you might have to shim it a little to fit the grill and hood lines better. But it is a very easy retrofit.
01Konvict
Boats n Hoes
Raleigh/SML
Depo Denali reps with plates on Mini H1s, then split the headlights and remove the amber = WIN!
YukonXL04
The Riverboat
Arlington, TX
What is the easiest way to get more light in my 12 Yukon. I am not technical AT all.
thanks!
Easiest? Pay someone to retrofit some for you lol.
Might have been luck in the NNBS section though as our headlights are different.
trooper003
