Denali roof **** removal tips?
felixgun
Lafayette, LA
Nice! I'm glad you put it back on! Denali's just look better with it on IMO.. it was meant to be!
M
mapkos13
Minneapolis
Check out grillcraft.com
Was looking at Grillcraft as it's something that seems to be within reason to do myself.
The only issue is they told me I had to use a standard Yukon grille meaning the Denali grille wouldn't work?
I thought they were pretty much the same? Anyone have any experience if I can use mine or would I need to buy a Yukon grille?
Thanks-
---------- Post added at 12:08 PM ---------- Previous post was at 12:06 PM ----------
After reading through this I took a good long look at mine and think I agree and will end up keeping mine on.
protonvx
If you do not intend on putting it back on, just use a slightly larger drill than the threaded hole and drill them out. It is similar to drilling out a rivet. Then you can buy these little plastic fasteners (similar to the ones used to hold fender liners to fenders) and silicone them in place. I did it and it looks so much better. With a little touch up paint you can hardly tell they are there. I think roof racks are pointless most of the time. But I also have an XL and own two trailers. I would never have used the roof rack.
imtye11
