Denali Slammed On 26's
Knobz
Knobz
Santa Cruz, CA
Hey can you get your truck on level ground and measure the back from ground to fenderlip again. Do you have a sound system or anything like that in the back? I knwo we tested it on your truck originally i think you said was 32? or 31.5
On level ground it's at 31 3/4" and I do have a kinda big system in the back.. the sub box prolly weighs about 175-200pounds..
---------- Post added at 07:43 AM ---------- Previous post was at 07:27 AM ----------
The front sits at 32 - 32.25"
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes 200 pounds taken off the back would put you at about 32.25. Thanks man. Oem on a 32 inch tall tire is about 38.25 to 38. So about 5.75 to 6 inch drop
Knobz
Knobz
Santa Cruz, CA
For sure.. Guess you gotta put some weight in the back to get in the 31's.. Steve Meades truck is just a tad bit lower than mine and he's got a huge system..
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
No problem. Ride your still ok with??
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you had a spare tire in there right?
On the springs you dont need to run isolators way i have the pig tails spun it will be fine no noise which is how i tested them.
relx
