Dexcool
hapyspaz
Austin
Couple things to add here. I also have worked on cars, managed shops, etc for 12+ years.
DexCools original design was flawed, the new stuff you buy is not. The chemicals in DexCool is actually designed for your vehicle. Every time I have had a customer come in that has green anti-freeze in it and is supposed to have DexCool, they have a blown waterpump bearing, or clogged thermostat, or clogged heater core, or ...
The parts of your cooling system are designed to work with these chemicals.
Da90
Tulsa, OK
It depends on what is knocking, but you might be able to get away with getting your heads redone and replacing lifters/rockers. Might be a little cheaper. But if its something deeper, a crate motor might be a good investment.
I'm not sure if you have priced a Vortec crate 350 lately but they are to the tune of about 5k for a long block. If anything I will buy a short block and send my heads to machine shop. I'm going to spend the same amount on a motor as the truck is worth. Once again if anyone knows where to get a motor let me know! I'm not in a huge rush to get it back on the road cause my family has cars for me to drive but I'm going to do it right!
steamroller
The South
No way is a Vortec longblock 350 $5k, unless your talking dealer prices
4 bolt mains:
http://www.summitracing.com/parts/NAL-12530283/
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=225981
2 bolt mains:
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=225980
http://www.summitracing.com/parts/NAL-12530282/
destroyer1362
A work in progress
Midlothian, TX
Da90, if I were you I would just do the 5.3 swap. Just look for a low mileage motor, 5.3s are dime a dozen. When all is said and done you will end up with more for less $$, than a new installed crate 350.
Da90
Tulsa, OK
Thanks for the links! I have not looked that hard so... I just googled it and came up some prices and I just stopped looking after I saw what they were asking. I have a buddy checking today from GM for a crate motor. He get cost plus 10% so I will see what he says!? Now that I think about it I may have been looking a 383s
