Diagnosis needed, no compression, help pls
1995Tahoe
San Antonio, TX
1995 Tahoe, 5.7L TBI
180k miles
"Rebuilt heads" from previous owner
Ran compression test, 8=120, 6=120, 4=110, cyl2 was at 0, needle didn't even flinch when cranking. New plug in 2 was covered with soot. Bad tick from passenger side of engine. Bad power, bad fuel consumption. Oil pressure goes down to almost 0 while driving, but will increase under high RPM. BUT no smoke. strange. what are the chances it's rings? Thanks all.
DallasTahoe
180k miles
Sounds familiar, I'm thinkin blown head gasket between cyls 2 & 4 or atleast partially between the two cyls.
DallasTahoe
Unless you have a camera to fit in the spark plug hole to see, or maybe pull a valve cover to see if maybe you have a broken valve spring, the only way to really know is to pull the head
SunlitComet
OBS Jedi-Do Good
unknown at this time.
a blown gasket will not cause a zero oil pressure issue. inspect your valve clearance for that dead cylinder and strongly consider you may need to tear off the top end for more clues.
SunlitComet
OBS Jedi-Do Good
also if the rings alone caused no compression you would see smoke. and if ring caused zero compression, you can kiss that piston and cylinder hole good bye. pressure issue is either bad bearings, clogged or broken pump or blown lifter but the last is very unlikely.
1995Tahoe
1995Tahoe
San Antonio, TX
What would I be looking for?
Inspect valve clearance like if it's hitting the piston?
Like above, what would I be looking for if I were to pull the head?
Thanks.
1995Tahoe
1995Tahoe
San Antonio, TX
Aaand it just backfired on me on the way to work. I was making a somewhat sharp turn, nothing crazy though.
jason05
