DIC problem
tbutts60
Language on DIC keeps changing from English to Spanish to French non stop. Tried almost everything to stop at English, but to no avail. HELP!!!!
ntxstallion
Are your buttons stuck a little? Mine did that when I first put it in? Try disconnecting for awhile and it might reset, ust a suggestion, but may work.
Administrator
Just learn how to speak and read spanish and french...:shrug:...there problem solved :High 5:
2005yukonxl
07, seroiusly u have an addiction to this site. every time i post or read a new post **** there u are replying to it hahaha are you one of them there "geeks"? :)
jimweis
Lancaster, PA
I had the same problem, invisible mold is shorting out the printed circuit on the back of the cluster. Take it out remove the back cover, brush the board with a stiff brush or toothbrush...fixed easy. I didn't beleve it until I did it myself.
jimweis
Lancaster, PA
I've been running for two weeks and over 1100 miles since brushing the mold off with no faults or foregin languages. That was a pain, the fix was simple:)
flipharvey187
