Didn't start then started right up.
Holt50
Holt50
Trying to find it but nothing comes up. I even tried looking up what's the difference between a two door full pump and a four door
Holt50
Holt50
I’d check for spark and fuel pressure, then. A parts store will have a tester, see if you have spark at all eight plugs or if any show a weaker spark compared to others.
Fuel pressure should be 60-66 psi with ignition on, engine off. A parts store would probably rent a test kit, or you can get one at Harbor Freight for pretty cheap.
As a quick check for a flaky coolant temperature sensor, try holding the gas to the floor while cranking.
You could also spray some starter fluid down the throttle body; replace the air intake before trying to start. If it starts and runs, it’s probably a weak fuel pump. If it starts and dies, then it’s a lack of fuel (bad pump or injector issue). If it doesn’t start at all, then it’s probably ignition related...check for spark then.
Well it seems that it worked itself out
tashaa95
