Sure. The yoke on the 14 bolt uses a bigger U-joint. A conversion U-joint has two different size spindles; one size for the driveshaft, another size for the rear axle yoke. The only downside to the conversion u-joints is that they aren't available in a permanently lubricated version; you have to lube them through a zirc fitting occasionally.
Also, I forgot to mention you'll need the plates that go under the axle as well, the ones the U-bolts clamp to. They aren't interchangeable with the 10 bolt version. While you're changing them, consider drilling a drain hole in the plates. When you look at them you'll see water can pool in the plate, causing corrosion on both the axle tube and plate.
