Differentials and transmission fluids changed
have a link? part number
Front Differential - 1.51 Quarts - 2 Bottles should do it - 89021671
Rear Differential - 2.15 Quarts - 2 Bottles should do it - 89021677 or 10-4016
Transfer Case - 1.6 Quarts - Dexron VI 10-9395 which is one gallon jug
These are fluids and capacities for 2007-2014 trucks with the NQH transfer case. Mine is a 2009. I was able to reuse my rear differential gasket.
Best deals are ever changing but I bought mine from a GM dealer on ebay and others on Amazon.
https://www.amazon.com/gp/product/B000QGOX1A/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01EKMGG92/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
http://www.ebay.com/itm/89021671-LU...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Doing this today. Is the 373 rearend open or slip? Aka do i need slip additive?
It is my understanding that all of the NNBS trucks came with positraction G80. Check your RPO sheet in the glovebox. Is yours a 2500 series truck? If you use GM OEM fluid, you do not need positraction additive.
Plimbob
Des Moines Iowa
I am going to change the trans fluid in the next week or so and wondered if you changed the shift solenoids when you did the fluid change out?
Waiting_to_Dye
