JochenWoern
So today I measured the dimension on each wheel/wheel well after my BELLTECH 2" inch rear drop/leveling kit installation.
I measured in the garage, truck nose in first, assuming that the garage floor is somewhat sloped towards the garage door and I measure the following dimensions from floor to bottom of fender/fender well:
FRONT DRIVER SIDE: 35" 7/16
FRONT PASSENGER SIDE: 35" 3/8
REAR DRIVER SIDE: 35"
REAR PASSENGER SIDE: 35" 1/4
Now with the naked eye I can not tell that the truck is NOT EXACTLY leveled and I assume that the not so leveled garage floor also plays a factor in all this, but do you guys think this should be adjusted? Is this normal and do you who have lowered your trucks also have similar tolerances?
I checked with TONY (NORCALSS) and he suggests if I am not happy to put some spacers in there to level everything out. Well, I am NOT UNHAPPY and I do like the space of the tire to the fender/wheel well and do not really want to mess with anything if you all think this is fine.
Thanks in advance.
Thanks in advance.
