Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
i bought the kit but the instructions say to tap into lower spot but i only see two spots on the same line as circled in the picture, can anyone tell me if either one is where i am to attach too please and thank you
no problem man. Kasey, over time AC refrigerant leaks, loses its chemicals leading the AC not to push cold air anymore. if thats the case first verify that your compressor is working. then check refrigerant and recharge ( refill) if needed.
if some cold air come out then your compressor is working. pop your hood, turn your ac on all the way and look behind the radiator fan ( where the belts are) your ac compressor should have its own belt. shine a light on it and make sure its spinning. i assume it is because your getting some cold air. but i would double check either way. mine stopped pushing cold air once. i popped the hood and noticed the belt was gone somewhere on the highway haha.
so ya checked my ac with the tester thing the pressure was high and colour good so i figured compressor must be bad then figure out that when my ac shows on its off so i just put at 15c and auto and the cold air flowed, going to get my money for the kit back
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
