do belltech spindles require a camber kit?
josueh95
i ordered some belltech spindles a couple of days ago and was wondaring if i will need a camber kit on 24s? my tires are 305/35/24 my stock keys are currently cranked down..you guys think that with spindles and my stock keys decranked it will align fine?
Big Buttons
The SS Burb
South Texas
When I did my 3/6 drop on my YXL with 24s I had no issues. Tony told me that more than 3" you will need the camber kit.
josueh95
josueh95
thanks guys! really had a doubt there..even with the keys decranked you think il be good?
Big Buttons
The SS Burb
South Texas
After a while I decranked bout .5-.75" and my alignment guy said the adjustments were maxed but it was within specs. So you should be good if the alignment guy knows what he is doing.
josueh95
josueh95
alright good to hear that! thanks, now to find a good shop that deals with lowered vehicles often. most around here usually come up with excuses that they cannot align it because its too low or watever excuses they make
Big Buttons
The SS Burb
South Texas
I actually found the guy that supplies the alignment machines for the whole city and he also did alignments so it just worked out.
M Hankel
Vancouver, WA
The thing with spindles is that they dont change a-arm geometry or ball joint angles at all. They only raise the spindle location which lowers the rig. So unless you have aftermarket keys that drastically change the geometry or ball joint angles you should be fine.
Mike
josueh95
josueh95
Mike
good info to know..i did hear the belltech spindles where taller than oem ones..does this change anything? havent really seen many people complain about belltech..i have some 4 inch belltech rear springs waiting to go on for the rear
Big Buttons
The SS Burb
South Texas
Fyi when I dropped my YXL it was with lower A arms. So that may have changed to geometry...
Jybfan04
