do belltech spindles require a camber kit?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
ive been sellling the belltech spindles since 2000 for the 00 up trucks and they have been fine. This is the reason i went with them on my new escalade. No issues and you keep the turning radius.
for the rear belltech 4 inch springs you will need shock extenders also will need the djm links and the new bumpstops i have in my store section. Unless you dont care about ride then just slap em in. You will also need to do the free travel mod by cutting bracket off frame.
josueh95
josueh95
if i do the free travel mod wont it just remove the bumstops? will order shock extenders and endlinks soon just gonna see how it rides and go from there..thanks for the tips
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you do the free travel mod you will have no bumpstops so what happens is when you bottom out it will be axle to frame and if you use no shock extenders the anlge of the shock is horrible which means ride suffers and shock will bottom out.
josueh95
josueh95
will see how low it gets and see from there but will get shock extenders and most likely do free travel mod..but now i got a question..i plan on installing the spindles tomarrow, now im not sure if il have time for an alignment right after because of work but will changing the spindles change the alignment dramatically? saturday morning will be the day il get a chance to align it but was wondaring if i should install em tomarrow or no
Fairweatherider
