Do I have cracked exhaust manifolds?
dbbd1
image.jpeg image.jpeg image.jpeg I would appreciate it if someone else would go out and check their 5.3 exhaust manifolds. On both sides, I have cracks or slits in the top part, I didn't check the underside. On both sides, the most forward and the most rearward bolt holes are solid. The other 3, in between each cylinder, on each side have a crack or factory slit going upwards from the bolts. The gaps are not consistent in size and, from just glancing at them, are not exactly regular.
Thanks.
PG01
Up here to the right
I can get pics if needed but it's pretty self-explanatory.
Thanks.
Pics of yours?
Will be easier to compare and then we can not answer you and take care if ours that may or may not be cracked....;)
I forgot, noticed it months ago on the yuk, mine has it too so no sweat bud.
dbbd1
dbbd1
Pics are in edited post #1.
Thanks.
Kpwweb
Pics of yours?
Yep. The cracks keep them from cracking while expanding and contracting.
SPIS
